@matt That did the trick. Managed to get Rockstor running yesterday with a functioning DPAA2 interface.
Did you ever try to pass more than one dpni with this image? In my case it seems to work for one. However, for my routing machine I am passing four dpni (+ neccessary companion resources) but only one is discovered by fsl_dpaa2_eth. For my old 5.4 guest kernel the discovery works for all dpni
Indeed I did not attempt more than one DPNI.
It looks like LF-3798: dprc-driver.c: resource pools are no longer initialized
is needed to ensure resources are correctly allocated between objects on bootup.
I’ve just rebuilt OpenWrt with this and two DPNIs are working.
