It also seems like I might need patches from here: Linux Wireless Mailing List - Patchwork
(top) AX is slower than (bottom) AC
Might be better to wait for a 22.03 or master based build. These should have everything for 11ax and MT7915 in there.
I’ve been working on it in the last couple of days but haven’t pushed a tree yet.
The top result looks a lot like 2.4GHz. Is it possible you have the 2.4G and 5G networks swapped around?
OK I’ll wait
I don’t think so. I’ve left one of the QCA cards in for the 2.4ghz network for now, mainly because it was really hard to tell the two mt7915 cards apart.
I don’t actually remember why I bought these two (the 1800 and 2400 cards) in particular, but it seems like the DBDC card isn’t fully supported yet.
About 20cm away from the Ten64 I hit 900 megabit on iperf3!
It drops off pretty rapidly after that - a good 500 to 600 megabit though
@mcbridematt just as a heads up, somewhere between r19302-df622768da and r19583-4e8d095013 the mt79 driver was really broken (testing on a non-Ten64 board though, so YMMV)
@mcbridematt is the branch in a state I can try on my device?
I’ve just pushed the 22.03 muvirt, it was delayed due to some 22.03 updates I had to dance around (firewall4, blockd) but otherwise it should be good to go.
