I have used luci to attempt to mount any connected USB as readonly:
- I added a mount point
- Device: /dev/sda1
- Mount point: /mnt/sda1
- File system: auto
- Mount options: default,ro
And saved and applied.
When I connect a USB device, /dev/sda1 is present, but is not mounted.
What have I missed?
If you want ANY usb drive to be auto mounted, ticking ‘Anonymous Mount’ and ‘Automount Filesystem’ up the top of Mount Points should be enough.
It looks like there is a problem with the ‘Check filesystems before mount’ option when it’s on, I’ll look into it.
For a specific USB drive, you can add by UUID. I wouldn’t recommend adding by device path as names can change on a system for various reasons (for example, a program having a file open on the device when it’s removed)
If it doesn’t work, check the system log. It could be something like a filesystem without an installed driver (e.g NTFS) or some weird settings (like FAT32 using a weird character set)
