Fedora works, what next
I managed to get fedora to boot (was not hard once I had it figured out…)
What I am interested in is if there is something more I need to do.
  • Anything regarding the device tree?
  • Anything regarding sensors?
    A lot of the docs assume an older kernel. I am now on 6.18, so I assume that many workarounds might not be needed anymore.
Also I see a new firmware here:
Is this something that is usable?
This one is usable, but it needs a bit more work before I am willing to make a formal release with it.
(This specific version was built to solve SFP issues with FreeBSD)
It includes new firmware components (TF-A and U-Boot) with patches I am staging for submission upstream, so some special features and edge case bugfixes are not present in this build.
If you are running a system with kernel >6.17 (including Fedora 43) you will be able to use the mainline kernel fan controller (emc2305) with this firmware.
This driver works differently to the out of tree one we published - it controls the fan duty cycle (0-100%) “open loop” instead of the RPM-based “closed loop” control we had.
The device tree included in this firmware includes some changes currently pending in the kernel.
A notable change (besides the fan setup) is to add line names to each GPIO which should make it easier to control cellular modems etc. I will update the manual with information on that in the near future.
The other sensors on the board aren’t available in the mainline kernel, these are available from our driver package.
Some like the pac1934 have industrial IO (IIO) which might be usable. There was an attempt to upstream another (emc181x) in the past but it didn’t go anywhere.
Thankfully, all the important things are now in the mainline kernel.
Some workarounds that are still needed on the Ten64 are:
  • IOMMU bypass mode needs to be disabled (arm-smmu.disable_bypass=0 on the kernel command line). NXP submitted a fix to the kernel a while ago but it does not work with EFI boot. There are various firmware workarounds I am looking into, but it isn’t a priority right now.
  • EFI variable support. Ten64 does not have a dedicated EFI variable storage, which can cause issues with distribution installers. The U-Boot community has come up with an alternative system, but I’m not sure if that has shipped in a major distribution yet.
