I am trying to install fedora from the baremetal appliance store. I am however seeing an error…
Using manipulator script: /tmp/manipulator-script.lua
lua: [string “/tmp/manipulator-script.lua”]:11: ERROR: A newer recovery firmware is required, please see https://archive.traverse.com.au
stack traceback:
[C]: in function ‘error’
[string “/tmp/manipulator-script.lua”]:11: in function ‘do_manipulate’
/usr/sbin/run-manipulate:58: in main chunk
[C]: ?
I have however installed the latest recovery image I could find (which is however a year old…)
After installing fedora this way the system no longer boots from EFI, so the manipulator script appears not to have done what is was supposed to do…
Note the Fedora by default puts SWAP on zram, so the swap partition that the manipulator creates is not used, and enabling it fails. I just removed the entry from /etc/fstab
Then I updated, and I am now on kernel 6.2
Any advantages that having this recent kernel brings?
