I am having some issues with ethernet interfaces not being consistently numbered:
For example after the latest boot:
[ 22.263298] fsl_dpaa2_eth dpni.7 eth0: configuring for inband/qsgmii link mode
[ 22.300689] fsl_dpaa2_eth dpni.8 eth1: configuring for inband/qsgmii link mode
[ 22.335246] fsl_dpaa2_eth dpni.9 eth2: configuring for inband/qsgmii link mode
[ 22.368789] fsl_dpaa2_eth dpni.6 eth3: configuring for inband/qsgmii link mode
[ 22.402577] fsl_dpaa2_eth dpni.5 eth4: configuring for inband/qsgmii link mode
[ 22.436457] fsl_dpaa2_eth dpni.4 eth5: configuring for inband/qsgmii link mode
[ 22.471804] fsl_dpaa2_eth dpni.3 eth6: configuring for inband/qsgmii link mode
[ 22.506846] fsl_dpaa2_eth dpni.2 eth7: configuring for inband/qsgmii link mode
[ 22.541962] fsl_dpaa2_eth dpni.1 eth8: configuring for inband/10gbase-r link mode
[ 22.575834] fsl_dpaa2_eth dpni.0 eth9: configuring for inband/10gbase-r link mode
[ 84.647351] fsl_dpaa2_eth dpni.7 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
eth0 in this case corresponds to the port labled ge2. This is a bit annoyig.
I will see if I can come up with some udev rules to have consistent naming (preferably with the same names as the box labels).
Has someone encountered (and solved?) this problem already?
