@mcbridematt @Krist To avoid polluting the other thread, decided to create new one.
Trying to create Rockstor vm in muvirt.
I have created /mnt/vm/rockstor.qcow2 with qemu-img command.
When using the following configuration
config vm 'rockstor'
option numprocs '2'
option memory '4096'
option mac '52:54:00:55:48:df'
list disks '/mnt/vm/rockstor.qcow2,serial=rroot'
list disks '/dev/sda,serial=disk1'
list disks '/dev/sdb,serial=disk2'
option provinplace '1'
option imageurl 'https://rockstor.com/downloads/installer/leap/15.3/aarch64/Rockstor-Leap15.3-ARM64EFI.aarch64-4.1.0-0.qcow2'
option checksum 'sha256:91ba94169b40fa32ac0430148cfe041b7883d37724cf781f1fab9e0dea82952b'
option imageformat 'qcow2'
option _downloading '-1'
I get
root@openwrt:~# muvirt-provision rockstor
muvirt-provision: [rockstor] downloading https://rockstor.com/downloads/installer/leap/15.3/aarch64/Rockstor-Leap15.3-ARM64EFI.aarch64-4.1.0-0.qcow2 to /mnt/vm//rockstor/image.bin
Using image file /mnt/vm//rockstor/image.bin
qemu-img: Could not open '/mnt/vm/rockstor.qcow2,serial=rroot /dev/sda,serial=disk1 /dev/sdb,serial=disk2': Could not open '/mnt/vm/rockstor.qcow2,serial=rroot /dev/sda,serial=disk1 /dev/sdb,serial=disk2': No such file or directory
vm
muvirt-provision: [rockstor] ERROR: Provision in place - /mnt/vm/rockstor.qcow2,serial=rroot /dev/sda,serial=disk1 /dev/sdb,serial=disk2 does not exist
Trying various options for disks, even with single disk line like
fails like above.
Decided the simplest configuration for disks with the following line only in the configuration
list disks '/mnt/vm/rockstor.qcow2'
Trying to provision again
Writing image to /mnt/vm/rockstor.qcow2
Starting VM rockstor
vm
muvirt-provision: [rockstor] First time boot failed to launch qemu (possibly missing storage/files), check system log for details
vm
muvirt-provision: [rockstor] First VM boot failed
Trying to rescue this by changing configuration to
option numprocs '2'
(removed the downloading and oneshot indicators, re-added disks with serials)
Starting the vm, and it silently fails with logs
root@openwrt:~# logread | tail
Sun Jul 24 08:28:14 2022 user.notice muvirt: rpc start request for rockstor
Now, I am out of ideas.
