Anyone running network level ad blocking? Especially on OpenWRT on the Ten64.
How did you set it up? I’m finding dnsmsq is a bit touchy - whatever OpenWRT is doing to manage it means it’ll go into a restart loop if anything is wrong with the config.
You can run Adguard home on the device as openwrt natively supports it.
I used this for many years.
I have not used openwrt on my Ten64 yet as I am reliant on the device being upstreamed to natively support openwrt kmods, but with other devices I have had AdGuard Home run on on OpenWRT ![]()
