Booting Linux kernel 7.2 or later on a Ten64 results in no network interfaces.
U-Boot writes the fsl-mc node’s compatible property without its terminating NUL, and since kernel commit drivers/of: validate live-tree string properties before string use (v7.2-rc1) the kernel rejects such a string, so the fsl_mc_bus driver does not bind.
The fix is one line in board/traverse/ten64/ten64.c (firmware v0.9.1; the same line is in mainline v2026.07 and in ten64-rebase-2026-02):
diff --git c/board/traverse/ten64/ten64.c i/board/traverse/ten64/ten64.c
index ac8c9a9a81a..7ee08d29870 100644
--- c/board/traverse/ten64/ten64.c
+++ i/board/traverse/ten64/ten64.c
@@ -177,7 +177,7 @@ void fdt_fixup_board_enet(void *fdt)
* Remove this as FreeBSD will only match "fsl,qoriq-mc"
* exactly on the DPAA2 bus/MC node.
- fdt_setprop(fdt, offset, "compatible", "fsl,qoriq-mc", 12);
+ fdt_setprop_string(fdt, offset, "compatible", "fsl,qoriq-mc");
if (get_mc_boot_status() == 0 &&
(is_lazy_dpl_addr_valid() || get_dpl_apply_status() == 0))
Workaround on a running kernel:
echo fsl_mc_bus > /sys/bus/platform/devices/80c000000.fsl-mc/driver_override
echo 80c000000.fsl-mc > /sys/bus/platform/drivers/fsl_mc_bus/bind
