I’ve got to the point where I finally want to set up VLANs
What options do I have for the following three scenarios:
Creating VLANs based on Ethernet port - I’m about to hang a small 100/1000 router off one port as I’ve run out of gigabit ports and have a few devices that need <=100 megabit each. I’d like to put them on their own VLAN at the same time and am happy for everything on a single Ten64 port be assigned a specific VLAN
Allowing my WAP to create VLANs - I realised the TP Link Omada I’m using supports PPSK to create VLANs based on different passwords for the same SSID. Cool, not quite sure how to use it, but will this work with the Ten64?
MAC-based VLAN - I think this is the one that’s least likely to work. I am not sure if it’s supported by OpenWRT at all and if it was, what the performance impact would be.
