Provisioning VM fails on download
I managed to set up muvirt, and get one of the “appliances” running, so provisioning a vm, starting it and running it works.
However I wanted to start a Fedora machien. And there I run in to issues. The machine goes in to status “download failed”
This is what I see in the log:
Sun Feb 22 16:05:21 2026 user.notice muvirt-provision: [fedora] downloading https://download.fedoraproject.org/pub/fedora/linux/releases/43/Server/aarch64/images/Fedora-Server-Guest-Generic-43-1.6.aarch64.qcow2 to /mnt/muvirtwork/imglibrary//EXTRA-fedora.img
Sun Feb 22 16:05:21 2026 daemon.err muvirt-provision[26269]: muvirt-provision: [fedora] downloading https://download.fedoraproject.org/pub/fedora/linux/releases/43/Server/aarch64/images/Fedora-Server-Guest-Generic-43-1.6.aarch64.qcow2 to /mnt/muvirtwork/imglibrary//EXTRA-fedora.img
Sun Feb 22 16:05:21 2026 daemon.err muvirt-provision[26269]:   % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
Sun Feb 22 16:05:21 2026 daemon.err muvirt-provision[26269]:                                  Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
Sun Feb 22 16:05:59 2026 daemon.err muvirt-provision[26269]:
  0  989M    0  239k    0     0   312k      0  0:54:00 --:--:--  0:54:00  312k
  0  989M    0 4591k    0     0  2589k      0  0:06:31  0:00:01  0:06:30 4326k
  1  989M    1  9.9M    0     0  3683k      0  0:04:35  0:00:02  0:04:33 4972k
  1  989M    1 16.9M    0     0  4612k      0  0:03:39  0:00:03  0:03:36 5712k
  2  989M    2 24.3M    0     0  5218k      0  0:03:14  0:00:04  0:03:10 6155k
  3  989M    3 32.9M    0     0  5846k      0  0:02:53  0:00:05  0:02:48 6694k
  4  989M    4 41.5M    0     0  6291k      0  0:02:41  0:00:06  0:02:35 7606k
  5  989M    5 51.7M    0     0  6820k      0  0:02:28  0:00:07  0:02:21 8562k
  6  989M    6 63.1M    0     0  7375k      0  0:02:17  0:00:08  0:02:09 9454k
  7  989M    7 74.0M    0     0  7759k      0  0:02:10  0:00:09  0:02:01  9.9M
  8  989M    8 87.9M    0     0  8362k      0  0:02:01  0:00:10  0:01:51 10.9M
 10  989M   10  100M    0     0  8767k      0  0:01:55  0:00:11  0:01:44 11.8M
 11  989M   11  113M    0
Sun Feb 22 16:05:59 2026 daemon.info muvirt-provision[26269]: Using image file /mnt/muvirtwork/imglibrary//EXTRA-fedora.img
Sun Feb 22 16:05:59 2026 daemon.info muvirt-provision[26269]: New volume created, path=/dev/mapper/vmdata-fedora
Sun Feb 22 16:05:59 2026 daemon.info muvirt-provision[26269]: Writing image to /dev/mapper/vmdata-fedora
Sun Feb 22 16:05:59 2026 daemon.err muvirt-provision[26269]: qemu-img: /dev/mapper/vmdata-fedora: error while converting raw: Cannot grow device files
Sun Feb 22 16:05:59 2026 daemon.info muvirt-provision[26269]: vm
Sun Feb 22 16:05:59 2026 user.notice muvirt-provision: [fedora] Failed to write image to /dev/mapper/vmdata-fedora
Sun Feb 22 16:05:59 2026 daemon.err muvirt-provision[26269]: muvirt-provision: [fedora] Failed to write image to /dev/mapper/vmdata-fedora
Looks like the download succeeds, but writing the image to the lv fails. But why it fails I cannot surmise from the logs. What could be the reason?
I suspect it’s not creating a big enough volume for the image. The Fedora 43 aarch64 image (qcow2) expands to 5GB so I would make sure the “disk size” setting is 6144MB (6GB) or higher.
The setting is under the “Provisioning” tab:
It looks like the provisioning has already created a volume , so you should remove that one with lvremove /dev/mapper/vmdata-fedora before attempting it again.
Unfortunately, I recently had to remove Fedora from the appliance store lists because some infrastructure changes at Fedora broke my method of finding image data. I will get it fixed soon.
(The appliance/bare metal store lists we publish contain a minimum disk size for each distribution)
If you need to setup a Fedora 43 VM, you can:
  1. Pick another appliance that uses cloud-init (like Ubuntu)
  2. Before starting on the new appliance, go to the provisioning tab and change the image URL to https://download.fedoraproject.org/pub/fedora/linux/releases/43/Cloud/aarch64/images/Fedora-Cloud-Base-Generic-43-1.6.aarch64.qcow2 and Image Hash to sha256:66031aea9ec61e6d0d5bba12b9454e80ca94e8a79c913d37ded4c60311705b8b
The URL is from the Fedora Cloud Download page, so I would re-check the URL and sha256 in case it changes :slight_smile:
