Hello,
I’m connected to the Ten64 board through a serial port and there are no problems per se. What I do see, however, is whenever I reboot the device and enter recovery mode, the serial port just “hangs” here:
[ 8.490632] xt_time: kernel timezone is -0000
[ 8.502271] PPP generic driver version 2.4.2
[ 8.506969] NET: Registered protocol family 24
[ 8.557332] kmodloader: 1 module could not be probed
[ 8.562322] kmodloader: - sha512-ce - 0
[ 11.506405] dpaa2_mac dpmac.7 (unnamed net_device) (uninitialized): Link is Up - 1Gbps/Full - flow control off
[ 11.512093] br-lan: port 1(eth0) entered blocking state
[ 11.519086] fsl_dpaa2_eth dpni.9 eth0: Link Event: state up
[ 11.521654] br-lan: port 1(eth0) entered disabled state
[ 11.523817] device eth0 entered promiscuous mode
[ 11.538769] br-lan: port 1(eth0) entered blocking state
[ 11.544003] br-lan: port 1(eth0) entered forwarding state
[ 11.553899] dpaa2_mac dpmac.8 (unnamed net_device) (uninitialized): Link is Up - 1Gbps/Full - flow control off
[ 11.568634] fsl_dpaa2_eth dpni.8 eth1: Link Event: state up
[ 11.577849] br-lan: port 2(eth1) entered blocking state
[ 11.583088] br-lan: port 2(eth1) entered disabled state
[ 11.590475] device eth1 entered promiscuous mode
[ 11.596152] br-lan: port 2(eth1) entered blocking state
[ 11.601379] br-lan: port 2(eth1) entered forwarding state
[ 11.609893] dpaa2_mac dpmac.9 (unnamed net_device) (uninitialized): Link is Up - 1Gbps/Full - flow control off
[ 11.624307] fsl_dpaa2_eth dpni.7 eth2: Link Event: state up
[ 11.631787] br-lan: port 3(eth2) entered blocking state
[ 11.637028] br-lan: port 3(eth2) entered disabled state
[ 11.644379] device eth2 entered promiscuous mode
[ 11.650059] br-lan: port 3(eth2) entered blocking state
[ 11.655282] br-lan: port 3(eth2) entered forwarding state
[ 11.663769] dpaa2_mac dpmac.10 (unnamed net_device) (uninitialized): Link is Up - 1Gbps/Full - flow control off
[ 11.678203] fsl_dpaa2_eth dpni.6 eth3: Link Event: state up
[ 11.685745] br-lan: port 4(eth3) entered blocking state
[ 11.690985] br-lan: port 4(eth3) entered disabled state
[ 11.698400] device eth3 entered promiscuous mode
[ 11.704088] br-lan: port 4(eth3) entered blocking state
[ 11.709315] br-lan: port 4(eth3) entered forwarding state
[ 11.718331] dpaa2_mac dpmac.5 (unnamed net_device) (uninitialized): Link is Up - 1Gbps/Full - flow control off
[ 11.732734] fsl_dpaa2_eth dpni.3 eth6: Link Event: state up
[ 12.517311] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
If I press CTRL+C, and then enter, Serial (the macOS app I’m using), will then reattach and show me I’m already logged in. The settings are as follows:
There are no ethernet cables plugged into eth0 thru eth6.
Is this behavior expected?
