I bought two Ten64 devices. This happened on both and it’s unclear how I managed to resolve it. After mounting it to a case, I upgraded the firmware as requested. Everything seemed fine.
I then booted back into recovery, and set the wan port using set-wan eth7. After that I ran appstore-list and baremetal-deploy ubuntu-hirsute /dev/nvme0n1, provided only a password and the interface eth7 and accepted the default for everything else and then rebooted.
I could reboot Ubuntu in this state as many times as I wanted, however, the image provided has outstanding packages, so I ran sudo apt update and sudo apt upgrade -y which succeeded. After rebooting, I’d allow Ten64 to boot normally, which then powered off with the following messages being spit out via the serial port:
... is now current device
Scanning nvme 0:f...
** Unable to read file / **
Found EFI removable media binary efi/boot/bootaa64.efi
device 0 offset 0x580000, size 0x40000
SF: 262144 bytes @ 0x580000 Read: OK
device 0 offset 0x600000, size 0x40000
SF: 262144 bytes @ 0x600000 Read: OK
TEN64 ft_board_setup start, blob 0000000090000000
INFO: RNG Desc SUCCESS with status 0
INFO: result ece7fbf0d7a1f6c5
TEN64 ft_board_setup end
Card did not respond to voltage select!
mmc_init: -95, time 18
Scanning disk esdhc@2140000.blk...
Disk esdhc@2140000.blk not ready
Scanning disk nvme#0.blk#0...
** Unrecognized filesystem type **
Found 4 disks
TEN64 ft_board_setup start, blob 0000000087f00000
TEN64 ft_board_setup already run, not doing anything
BootOrder not defined
EFI boot manager: Cannot load any image
840024 bytes read in 1 ms (801.1 MiB/s)
TEN64 ft_board_setup start, blob 0000000087ee7000
Could not get variable storage info: Unsupported
Could not create MokListRT: Unsupported
Could not create MokListXRT: Unsupported
Something has gone seriously wrong: import_mok_state() failed: Unsupported
poweroff ...
INFO: PSCI Power Domain Map:
INFO: Domain Node : Level 2, parent_node -1, State ON (0x0)
INFO: Domain Node : Level 1, parent_node 0, State ON (0x0)
INFO: Domain Node : Level 1, parent_node 0, State OFF (0x2)
INFO: CPU Node : MPID 0x0, parent_node 1, State ON (0x0)
INFO: CPU Node : MPID 0xffffffffffffffff, parent_node 1, State OFF (0x2)
INFO: CPU Node : MPID 0xffffffffffffffff, parent_node 2, State OFF (0x2)
The only recourse is to boot back into the recovery, and repeat steps.
Is this expected, and if so, how would one update Ubuntu 21.04?
