I was able to get the system to work again via using flash.sh in the recovery image and then it seemed to successfully boot the Debian Unstable system on /dev/nvme0n1.
I think this is because there was no environment saved on the flash before hand, and the baremetal-deploy will write two U-Boot variables for the network mode setting (depending on what combination of settings the target distribution is known to support)
I’ll see if I can add detection to the recovery firmware so the U-Boot environment can’t be touched if it’s empty.
(You can also download the recovery.itb file from here and manually update )
It will refuse to set environment variables if the U-Boot environment appears to blank/missing or corrupted:
$ mtd erase ubootenv
$ baremetal-deploy traverse-openwrt-arm64 /dev/nvme0n1
ERROR: The U-Boot environment on flash is missing or corrupted
Not setting the management mode variables (gbemode,sfpmode) because of this
Reboot your system and use these u-boot commands to get back to a normal state:
env default -a && saveenv
Separately ./flash.sh now prompts to reset and save the environment on next boot, so the situation with an unsaved environment is less likely to occur.
