Trying to decide between MuVirt and OpenWRT
I’m planning to migrate my main router from an x86 machine running OpenWRT to the Traverse Ten64.
I’m still debating whether to run muVirt on the thing, or run plain OpenWRT. My primary use case for guest VMs is just Home Assistant OS, which I currently run as a VM on an N97 running Proxmox. I have other VMs that will stay on the N97 machine anyway.
I noticed that a couple of the packages I use, and their dependencies and related packages, aren’t available on muvirt like they are on OpenWRT.
  • luci-app-nlbwmon: for per-machine traffic monitoring
  • luci-app-vnstat2: for overall bandwidth monitoring
  • luci-app-lxc: for running PiHole on the router cleanly (doesn’t need a full VM)
  • apcupsd: for talking to the UPS, because NUT doesn’t fully support it
  • luci-app-nut: for talking to apcupsd and exposing it over the network
luci-app-nut - git-24.346.66847-1bb28ba
nut - 2.8.0-3
nut-avahi-service - 2.8.0-3
nut-common - 2.8.0-3
nut-driver-apcupsd-ups - 2.8.0-3
nut-server - 2.8.0-3
nut-upsc - 2.8.0-3
nut-upscmd - 2.8.0-3
nut-web-cgi - 2.8.0-3
How hard would it be to add those?
Incidentally, is it supported to run Docker directly on MuVirt?
muvirt is mostly a package of scripts to manage VM’s on OpenWrt. There are only some minor differences between in the base OS these days (it is mostly ensuring all the correct options are set) and the hope is that eventually the muvirt functions will be usable on standard OpenWrt.
There are some divergences from OpenWrt to enable all the features to work, such as using nginx as a proxy infront of uhttpd to allow the VM web consoles to work.
The difference in package list is not intentional, it’s just that muvirt is configured separately from OpenWrt. muvirt used to be much thinner as the intention was that all the “real” apps were run under VMs.
As long as the packages aren’t tied to the kernel version, the easiest way is just to add the official OpenWrt.org repositories (for the corresponding OpenWrt release) to your opkg/apk repo list and install them from there.
Otherwise you can use the OpenWrt or muvirt SDK packages (like muvirt-sdk-24.10-SNAPSHOT-armsr-armv8_gcc-13.3.0_musl.Linux-x86_64.tar.zst) to build the packages and install them.
I’m happy to take requests to add them to the package list for (our) OpenWrt or muvirt.
We used to have some constraints on our CI/CD system which limited the number of packages we could build, but it’s much better now.
Yes, and normal OpenWrt as well, but the Docker networking does not integrate with OpenWrt’s firewall system.
You need to do some configuration to allow the containers to access the internet, and basically treat them like separate devices on your network (e.g add firewall rules to port forward instead of using docker’s port forward function).
If you have things that are highly dependent on docker networking behaviours like the port forward or inter-container links, it might be better to put all your Docker/container workloads in a separate VM where it won’t conflict with OpenWrt’s functions.
(Also, make sure you mount a separate partition for Docker’s /var/lib/docker!)
FYI, You can run a port of proxmox on Arm machines like the Ten64
The best way to do it on a Ten64 is by installing Debian and adding repos for the community port, effectively converting from a Debian to Proxmox install.
See Install Proxmox VE on Debian bookworm · jiangcuo/Proxmox-Port Wiki · GitHub
I wrote an install script for an earlier port (called PiMox) and you might find some hints here: GitHub - mcbridematt/pimox-ten64: Proxmox/PiMox V7 installer script for Ten64, but the above install guide should cover everything.
Looks like I was able to install those packages just fine on muvirt. Does opkg know to prioritize distfeeds over customfeeds? If I go with that route, how would I deal with sysupgrade?
Additionally, are there any recommendations for how you’d make backups of VMs on muVirt?
If I wanted to include openwrt_nand in place of dhcp/pxe in the default boot order, how would I do that? If I try as the instructions say, I get: Unknown uclass 'openwrt_nand' in label
My u-boot version:
U-Boot 2023.10-rc3 (Sep 23 2023 - 05:51:23 +0000)
aarch64-linux-gnu-gcc (Linaro GCC 7.5-2019.12) 7.5.0
GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706
My primary reason for wanting the host OS to be the router is so there’s never a case where a VM failing to start brings down the whole network.
Here’s what I get with boot_targets set to openwrt_nand nvme0 usb0 mmc0 scsi0:
INFO:    PSCI Power Domain Map:
INFO:      Domain Node : Level 2, parent_node -1, State ON (0x0)
INFO:      Domain Node : Level 1, parent_node 0, State ON (0x0)
INFO:      Domain Node : Level 1, parent_node 0, State OFF (0x2)
INFO:      CPU Node : MPID 0x0, parent_node 1, State ON (0x0)
INFO:      CPU Node : MPID 0xffffffffffffffff, parent_node 1, State OFF (0x2)
INFO:      CPU Node : MPID 0xffffffffffffffff, parent_node 2, State OFF (0x2)
INFO:    RCW BOOT SRC is QSPI
WARNING: Using I2C3 for DDR SPD
INFO:    platform clock 700000000
INFO:    DDR PLL 2100000000
INFO:    time base 11 ms
INFO:    Parse DIMM SPD(s)
INFO:    Controller 0
INFO:    DIMM 0
INFO:    addr 0x51
INFO:    checksum 0xc06c86cb
INFO:    n_ranks 2
INFO:    rank_density 0x400000000
INFO:    capacity 0x800000000
INFO:    die density 0x6
INFO:    primary_sdram_width 64
INFO:    ec_sdram_width 8
INFO:    device_width 8
INFO:    package_3ds 0
INFO:    rc 0x26 (Raw card G1)
INFO:    rdimm 0
INFO:    mirrored_dimm 1
INFO:    n_row_addr 17
INFO:    n_col_addr 10
INFO:    bank_addr_bits 0
INFO:    bank_group_bits 2
INFO:    edc_config 2
INFO:    burst_lengths_bitmask 0xc
INFO:    tckmin_x_ps 625
INFO:    tckmax_ps 1600
INFO:    caslat_x 0x17ffc00
INFO:    taa_ps 13750
INFO:    trcd_ps 13750
INFO:    trp_ps 13750
INFO:    tras_ps 32000
INFO:    trc_ps 45750
INFO:    trfc1_ps 350000
INFO:    trfc2_ps 260000
INFO:    trfc4_ps 160000
INFO:    tfaw_ps 21000
INFO:    trrds_ps 2500
INFO:    trrdl_ps 4900
INFO:    tccdl_ps 5000
INFO:    trfc_slr_ps 0
INFO:    twr_ps 15000
INFO:    refresh_rate_ps 7800000
INFO:    dq_mapping 0xb
INFO:    dq_mapping 0x2b
INFO:    dq_mapping 0xc
INFO:    dq_mapping 0x16
INFO:    dq_mapping 0x36
INFO:    dq_mapping 0x15
INFO:    dq_mapping 0x2c
INFO:    dq_mapping 0x35
INFO:    dq_mapping_ors 1
INFO:    DIMM 1
INFO:    done with controller 0
INFO:    cal cs
INFO:    cs_in_use = 3
INFO:    cs_on_dimm[0] = 3
NOTICE:  UDIMM 9965657-052.A00G
INFO:    Time after parsing SPD 562 ms
INFO:    Synthesize configurations
INFO:    cs 0
INFO:         odt_rd_cfg 0x0
INFO:         odt_wr_cfg 0x5
INFO:         odt_rtt_norm 0x3
INFO:         odt_rtt_wr 0x0
INFO:         auto_precharge 0
INFO:    cs 1
INFO:         odt_wr_cfg 0x0
INFO:         odt_rtt_norm 0x0
INFO:    cs 2
INFO:    cs 3
INFO:    ctlr_init_ecc 1
INFO:    x4_en 0
INFO:    ap_en 0
INFO:    ctlr_intlv 0
INFO:    ctlr_intlv_mode 0
INFO:    ba_intlv 0x40
INFO:    data_bus_used 0
INFO:    otf_burst_chop_en 1
INFO:    burst_length 0x6
INFO:    dbw_cap_shift 0
INFO:    Assign binding addresses
INFO:    ctlr_intlv 0
INFO:    rank density 0x400000000
INFO:    CS 0
INFO:        base_addr 0x0
INFO:        size 0x800000000
INFO:    CS 1
INFO:        base_addr 0x0
INFO:    base 0x0
INFO:    Total mem by assignment is 0x800000000
INFO:    Calculate controller registers
INFO:    Skip CL mask for this speed 0x4000
INFO:    Skip caslat 0x4000
INFO:    cs_in_use = 0x3
INFO:    cs0
INFO:       _config = 0x80050522
INFO:    cs[0].bnds = 0x7ff
INFO:    cs1
INFO:       _config = 0x80000522
INFO:    cs[1].bnds = 0x7ff
INFO:    sdram_cfg[0] = 0xe5004000
INFO:    sdram_cfg[1] = 0x401151
INFO:    sdram_cfg[2] = 0x0
INFO:    timing_cfg[0] = 0xd1770018
INFO:    timing_cfg[1] = 0xf2fc8245
INFO:    timing_cfg[2] = 0x594197
INFO:    timing_cfg[3] = 0x2161100
INFO:    timing_cfg[4] = 0x220002
INFO:    timing_cfg[5] = 0x5401400
INFO:    timing_cfg[6] = 0x0
INFO:    timing_cfg[7] = 0x26600000
INFO:    timing_cfg[8] = 0x5446a00
INFO:    timing_cfg[9] = 0x0
INFO:    dq_map[0] = 0x2eb32bac
INFO:    dq_map[1] = 0x2d6d95b0
INFO:    dq_map[2] = 0x2f55b658
INFO:    dq_map[3] = 0xd8cac001
INFO:    sdram_mode[0] = 0x3010631
INFO:    sdram_mode[1] = 0x100200
INFO:    sdram_mode[9] = 0x8400000
INFO:    sdram_mode[8] = 0x500
INFO:    sdram_mode[2] = 0x10631
INFO:    sdram_mode[3] = 0x100200
INFO:    sdram_mode[10] = 0x400
INFO:    sdram_mode[11] = 0x8400000
INFO:    sdram_mode[4] = 0x10631
INFO:    sdram_mode[5] = 0x100200
INFO:    sdram_mode[12] = 0x400
INFO:    sdram_mode[13] = 0x8400000
INFO:    sdram_mode[6] = 0x10631
INFO:    sdram_mode[7] = 0x100200
INFO:    sdram_mode[14] = 0x400
INFO:    sdram_mode[15] = 0x8400000
INFO:    eor = 0x40000000
INFO:    interval = 0x1ffe07ff
INFO:    zq_cntl = 0x8a090705
INFO:    ddr_sr_cntr = 0x0
INFO:    clk_cntl = 0x2400000
INFO:    cdr[0] = 0x80080000
INFO:    cdr[1] = 0xc0
INFO:    wrlvl_cntl[0] = 0x8675f605
INFO:    wrlvl_cntl[1] = 0x704080b
INFO:    wrlvl_cntl[2] = 0xf0c0d0a
INFO:    debug[28] = 0x7b
INFO:    Time before programming controller 830 ms
INFO:    Program controller registers
INFO:    total size 32 GB
INFO:    Need to wait up to 8160 ms
INFO:    Reading debug[9] as 0x2d003100
INFO:    Reading debug[10] as 0x2a003200
INFO:    Reading debug[11] as 0x39004100
INFO:    Reading debug[12] as 0x3c003f00
INFO:    cpo_min 0x2a
INFO:    cpo_max 0x41
INFO:    debug[28] 0x6a007b
WARNING: Warning: A009942 requires setting cpo_sample to 0x5c
INFO:    *0x1080000 = 0x7ff
INFO:    *0x1080008 = 0x7ff
INFO:    *0x1080080 = 0x80050522
INFO:    *0x1080084 = 0x80000522
INFO:    *0x1080100 = 0x2161100
INFO:    *0x1080104 = 0xd1770018
INFO:    *0x1080108 = 0xf2fc8245
INFO:    *0x108010c = 0x594197
INFO:    *0x1080110 = 0xe5004000
INFO:    *0x1080114 = 0x401141
INFO:    *0x1080118 = 0x3010631
INFO:    *0x108011c = 0x100200
INFO:    *0x1080120 = 0x1600086b
INFO:    *0x1080124 = 0x1ffe07ff
INFO:    *0x1080128 = 0xdeadbeef
INFO:    *0x1080130 = 0x2400000
INFO:    *0x1080160 = 0x220002
INFO:    *0x1080164 = 0x5401400
INFO:    *0x108016c = 0x26600000
INFO:    *0x1080170 = 0x8a090705
INFO:    *0x1080174 = 0xc675f605
INFO:    *0x1080190 = 0x704080b
INFO:    *0x1080194 = 0xf0c0d0a
INFO:    *0x1080200 = 0x10631
INFO:    *0x1080204 = 0x100200
INFO:    *0x1080208 = 0x10631
INFO:    *0x108020c = 0x100200
INFO:    *0x1080210 = 0x10631
INFO:    *0x1080214 = 0x100200
INFO:    *0x1080220 = 0x500
INFO:    *0x1080224 = 0x8400000
INFO:    *0x1080228 = 0x400
INFO:    *0x108022c = 0x8400000
INFO:    *0x1080230 = 0x400
INFO:    *0x1080234 = 0x8400000
INFO:    *0x1080238 = 0x400
INFO:    *0x108023c = 0x8400000
INFO:    *0x1080250 = 0x5446a00
INFO:    *0x1080270 = 0xffff
INFO:    *0x1080280 = 0xeedeeedd
INFO:    *0x1080284 = 0xedeedddd
INFO:    *0x1080288 = 0x11211122
INFO:    *0x108028c = 0x12112222
INFO:    *0x1080290 = 0xb3de0001
INFO:    *0x1080400 = 0x2eb32bac
INFO:    *0x1080404 = 0x2d6d95b0
INFO:    *0x1080408 = 0x2f55b658
INFO:    *0x108040c = 0xd8cac001
INFO:    *0x1080b20 = 0x8080
INFO:    *0x1080b24 = 0x80000000
INFO:    *0x1080b28 = 0x80080000
INFO:    *0x1080b2c = 0xc0
INFO:    *0x1080bf8 = 0x20502
INFO:    *0x1080bfc = 0x100
INFO:    *0x1080c00 = 0x40000000
INFO:    *0x1080f04 = 0x2
INFO:    *0x1080f08 = 0x9
INFO:    *0x1080f0c = 0x14000c20
INFO:    *0x1080f24 = 0x2d003100
INFO:    *0x1080f28 = 0x2a003200
INFO:    *0x1080f2c = 0x39004100
INFO:    *0x1080f30 = 0x3c003f00
INFO:    *0x1080f34 = 0x35007000
INFO:    *0x1080f48 = 0x1
INFO:    *0x1080f4c = 0x94000000
INFO:    *0x1080f50 = 0xc000f00
INFO:    *0x1080f54 = 0xa001300
INFO:    *0x1080f58 = 0x18002000
INFO:    *0x1080f5c = 0x1b001d00
INFO:    *0x1080f60 = 0x16000000
INFO:    *0x1080f64 = 0x9000
INFO:    *0x1080f68 = 0x20
INFO:    *0x1080f70 = 0x6a007b
INFO:    *0x1080f94 = 0x80000000
INFO:    *0x1080f9c = 0x29002800
INFO:    *0x1080fa0 = 0x28002800
INFO:    *0x1080fa4 = 0x28002600
INFO:    *0x1080fa8 = 0x2b002900
INFO:    *0x1080fac = 0x27000000
INFO:    *0x1080fb0 = 0x3
INFO:    *0x1080fb4 = 0x1f1d1c1e
INFO:    *0x1080fb8 = 0x1e1d1d1d
INFO:    *0x1080fbc = 0x1e1d1d1f
INFO:    *0x1080fc0 = 0x1d1e1c1b
INFO:    *0x1080fc4 = 0x1e1d1b1f
INFO:    *0x1080fc8 = 0x1c1d1f1d
INFO:    *0x1080fcc = 0x1e1c1c1d
INFO:    *0x1080fd0 = 0x1b1c1d1c
INFO:    *0x1080fd4 = 0x1e1e1b1e
INFO:    *0x1080fd8 = 0x1e1e1d1c
INFO:    *0x1080fdc = 0x1e1a1a1b
INFO:    *0x1080fe0 = 0x1c1c1d1a
INFO:    *0x1080fe4 = 0x1f1f1d20
INFO:    *0x1080fe8 = 0x1e201d1e
INFO:    *0x1080fec = 0x1e1e1d1e
INFO:    *0x1080ff0 = 0x1d1f1f1c
INFO:    *0x1080ff4 = 0x1e1d1a1d
INFO:    *0x1080ff8 = 0x1c1d1d1b
INFO:    *0x1080ffc = 0x1f000000
NOTICE:  32 GB DDR4, 64-bit, CL=15, ECC on, CS0+CS1
INFO:    Time used by DDR driver 4396 ms
NOTICE:  BL2: v1.5(debug):
NOTICE:  BL2: Built : 05:52:13, Sep 23 2023
INFO:    Configuring TrustZone Controller
INFO:    Value of region base = ffe00000
INFO:    Value of region base = 1ffe00000
INFO:    Value of region base = fbe00000
INFO:    Value of region base = 8880000000
INFO:    BL2: Doing platform setup
INFO:    BL2: Loading image id 3
INFO:    Loading image id=3 at address 0xfbe00000
INFO:    Image id=3 loaded: 0xfbe00000 - 0xfbe0c16c
INFO:    BL2: Loading image id 5
INFO:    Loading image id=5 at address 0x82000000
INFO:    Image id=5 loaded: 0x82000000 - 0x82153900
NOTICE:  BL2: Booting BL31
INFO:    Entry point address = 0xfbe00000
INFO:    SPSR = 0x3cd
NOTICE:  BL31: v1.5(debug):
NOTICE:  BL31: Built : 05:52:18, Sep 23 2023
NOTICE:  Welcome to LS1088 BL31 Phase
INFO:    GICv3 without legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    BL31: Initializing runtime services
WARNING: BL31: cortex_a53: CPU workaround for 835769 was missing!
WARNING: BL31: cortex_a53: CPU workaround for 843419 was missing!
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x82000000
INFO:    SPSR = 0x3c9
SoC:  LS1088AE Rev1.0 (0x87030010)
Clock Configuration:
       CPU0(A53):1600 MHz  CPU1(A53):1600 MHz  CPU2(A53):1600 MHz
       CPU3(A53):1600 MHz  CPU4(A53):1600 MHz  CPU5(A53):1600 MHz
       CPU6(A53):1600 MHz  CPU7(A53):1600 MHz
       Bus:      700  MHz  DDR:      2100 MT/s
Reset Configuration Word (RCW):
       00000000: 4000541c 00000040 00000000 00000000
       00000010: 00000000 000a0000 00300000 00000000
       00000020: 010011a0 00002580 00000000 00000000
       00000030: 013fe60a 00000000 00002c03 00000000
       00000040: 00000000 00000000 00000000 00000000
       00000050: 00000000 00000000 00000000 00000000
       00000060: 00000000 00000000 00000089 000009e7
       00000070: 44110000 0d007755
DRAM:  31.9 GiB
DDR    31.9 GiB (DDR4, 64-bit, CL=15, ECC on)
       DDR Chip-Select Interleaving Mode: CS0+CS1
Core:  68 devices, 24 uclasses, devicetree: separate
WDT:   Not starting wdt@c000000
WDT:   Not starting wdt@c010000
WDT:   Not starting wdt@c020000
WDT:   Not starting wdt@c030000
WDT:   Not starting wdt@c100000
WDT:   Not starting wdt@c110000
WDT:   Not starting wdt@c120000
WDT:   Not starting wdt@c130000
Using SERDES1 Protocol: 29 (0x1d)
Using SERDES2 Protocol: 20 (0x14)
MMC:   FSL_SDHC: 0
Loading Environment from SPIFlash... SF: Detected en25s64 with page size 256 Bytes, erase size 64 KiB, total 8 MiB
OK
PCIe1: pcie@3400000 Root Complex: no link
PCIe2: pcie@3500000 Root Complex: x1 gen2
PCIe3: pcie@3600000 Root Complex: x2 gen3
In:    serial@21c0500
Out:   serial@21c0500
Err:   serial@21c0500
Model: Traverse Ten64
Board: 1064-0201C, boot from QSPI
Controller: firmware 1.1.5
DPMAC7: 00:0A:FA:xx:yy:z5
DPMAC8: 00:0A:FA:xx:yy:z6
DPMAC9: 00:0A:FA:xx:yy:z7
DPMAC10: 00:0A:FA:xx:yy:z8
DPMAC3: 00:0A:FA:xx:yy:z9
DPMAC4: 00:0A:FA:xx:yy:zA
DPMAC5: 00:0A:FA:xx:yy:zB
DPMAC6: 00:0A:FA:xx:yy:zC
DPMAC2: 00:0A:FA:xx:yy:zD
DPMAC1: 00:0A:FA:xx:yy:zE
Retimer: (retimer on, resetting...) DS110DF410 found
OK
Fan:  PWM reset done
USB Hub:    OK
Bus usb@3100000: Register 200017f NbrPorts 2
Starting the controller
USB XHCI 1.00
Bus usb@3110000: Register 200017f NbrPorts 2
USB XHCI 1.00
scanning bus usb@3100000 for devices... 1 USB Device(s) found
scanning bus usb@3110000 for devices... 3 USB Device(s) found
Net:   eth9: DPMAC1@10gbase-r, eth8: DPMAC2@10gbase-r, eth4: DPMAC3@qsgmii, eth5: DPMAC4@qsgmii, eth6: DPMAC5@qsgmii, eth7: DPMAC6@qsgmii, eth0: DPMAC7@qsgmii, eth1: DPMAC8@qsgmii, eth2: DPMAC9@qsgmii, eth3: DPMAC10@qsgmii
device 0 offset 0x300000, size 0x200000
SF: 2097152 bytes @ 0x300000 Read: OK
device 0 offset 0x5c0000, size 0x40000
SF: 262144 bytes @ 0x5c0000 Read: OK
crc32+ MC firmware version 10.36.0
fsl-mc: Booting Management Complex ... SUCCESS
fsl-mc: Management Complex booted (version: 10.36.0, boot status: 0x1)
device 0 offset 0x580000, size 0x40000
SF: 262144 bytes @ 0x580000 Read: OK
default DPL loaded
Autoboot in 10 seconds, press 's' to stop and bring up boot menu
Scanning for bootflows in all bootdevs
Seq  Method       State   Uclass    Part  Name                      Filename
Scanning global bootmeth 'efi_mgr':
Hunting with: simple_bus
Found 0 extension board(s).
Scanning bootdev 'nvme#0.blk#1.bootdev':
No bootdevs for 'usb0'
Scanning bootdev 'esdhc@2140000.bootdev':
  0  efi          ready   mmc          1  esdhc@2140000.bootdev.par efi/boot/bootaa64.efi
** Booting bootflow 'esdhc@2140000.bootdev.part_1' with efi
Working FDT set to 90000000
TEN64: Using legacy fan device tree overlay
Missing TPMv2 device for EFI_TCG_PROTOCOL
INFO:    RNG Desc SUCCESS with status 0
INFO:    result f411a388b3aee7b8
Booting /efi\boot\bootaa64.efi
Welcome to GRUB!
DPMAC7@qsgmii Waiting for PHY auto negotiation to complete......... TIMEOUT !
DPMAC7@qsgmii: Could not initialize
DPMAC8@qsgmii Waiting for PHY auto negotiation to complete......... TIMEOUT !
DPMAC8@qsgmii: Could not initialize
DPMAC9@qsgmii Waiting for PHY auto negotiation to complete......... TIMEOUT !
DPMAC9@qsgmii: Could not initialize
DPMAC10@qsgmii Waiting for PHY auto negotiation to complete......... TIMEOUT !
DPMAC10@qsgmii: Could not initialize
error: serial port `com0' isn't found.
error: terminal `serial' isn't found.
Then Grub boots, but it’s muVirt, not openwrt on NAND.
Apologies, I need to update the instructions.
The NAND boot isn’t (yet) integrated into the new “bootflow” system in the newer U-Boot versions.
I am working on a U-Boot update at the moment, so I might be able to fix this.
If you want to boot into NAND by default, you can override the default boot command in U-Boot like so (interrupt the boot sequence by hitting s when prompted to get a prompt):
setenv bootcmd 'run bootcmd_openwrt_nand'
saveenv
To do the reverse (NAND boot after all other options are exhausted), I think you could try something like:
setenv boot_targets '...' (without dhcp/pxe)
setenv bootcmd 'bootflow scan -lb; run bootcmd openwrt_nand'
saveenv
(This will only work if none of the NVME/SD/USB devices have no EFI or other bootable files, or you configure GRUB on those devices to exit back to firmware)
As far as I know, opkg will prioritize feeds in the order they are read, which I think is distfeeds → customfeeds
When upgrading, you will need to add the repository URLs again and re-install the packages.
(For both us and upstream OpenWrt, the repositories are built for the exact release or snapshot version, so you don’t want to have old repository references carry across)
Another method would be use ImageBuilder to build your desired packages into an image which you then upload to your system.
I keep a collection of scripts for various custom images and have them setup so I just download the new copy of ImageBuilder and change the script to operate on the new ImageBuilder folder.
It’s not quite “backup”, but when I have to move VMs from one host to another, I do something like this:
# From sending system
/etc/init.d/muvirt stop vmmname
dd if=/dev/mapper/vmdata-vmname | gzip -c | nc -q 0 <otherhost> 1234
# Receiving system
lvcreate --name vmname --size XGiB vmdata
nc -l 1234 | gunzip -c | dd of=/dev/mapper/vmdata-vmname
If you are using the LVM storage manged by muvirt, you could use LVM snapshots to make a copy of a live VM.
I came back to this for the first time in a while. The fan noise is actually more than I was expecting, partly due to the grills on the case, so I’ve had the thing turned off, and hadn’t had the time to play around with it.
I went to try swapping my OpenWRT x86 box for this device, only to find that the LAN didn’t work at all, thanks to the SFP+ port not passing any data.
The DAC: SFP-H10GB-CU2M (I also have a -CU3M).
The switch: TP-Link Omada SX3008F
The behavior: Both ends see the DAC model, and the Ten64 sees the link as up, but the Omada switch sees the link as down.
The DAC works fine between the Omada switch and other devices, and the DAC works fine between the Ten64 and other devices, but the DAC does not work between the Ten64 and the Omada switch. The same applies to another DAC from the same vendor.
I’m using upstream OpenWrt 24.10.2, with kernel 6.6.93, because the Traverse package repos are missing so many packages.
EDIT: … and now the SFP+ DAC seems to be working again? I wonder if it was the Omada switch screwing things up?
I’d like to find a way to use upstream OpenWRT MTD/NAND builds while still having some degree of fan control. Also, attended-sysupgrade doesn’t work, it claims the image doesn’t exist.
EDIT2: Tried again; now SFP+ works, but when I benchmarked with SQM enabled, I only got about 600 megabits through the Ten64, so I had to go back to the x86-64 box.
I’m posting as a new message this time instead of as an edit.
I got the DACs to work by setting sfpmode to legacy, but SQM is still behaving oddly on upstream OpenWRT: with CAKE enabled (default profile), I can get 1.2 gigabits per second outbound on eth9 but inbound only gives about 600 megabits per second.
Checking the version of recovery:
ten64-recovery master, 827157362_2023-04-04
From /etc/os-release:
NAME="muvirt"
VERSION="22.03-SNAPSHOT+traverse"
ID="muvirt"
ID_LIKE="lede openwrt"
PRETTY_NAME="muvirt 22.03-SNAPSHOT+traverse"
VERSION_ID="22.03-snapshot+traverse"
HOME_URL="https://openwrt.org/"
BUG_URL="https://bugs.openwrt.org/"
SUPPORT_URL="https://forum.openwrt.org/"
BUILD_ID="r0+20138-46c43831bb"
OPENWRT_BOARD="armvirt/64"
OPENWRT_ARCH="aarch64_generic"
OPENWRT_TAINTS="no-all busybox"
OPENWRT_DEVICE_MANUFACTURER="OpenWrt"
OPENWRT_DEVICE_MANUFACTURER_URL="https://openwrt.org/"
OPENWRT_DEVICE_PRODUCT="Generic"
OPENWRT_DEVICE_REVISION="v0"
OPENWRT_RELEASE="muvirt 22.03-SNAPSHOT+traverse r0+20138-46c43831bb"
Apologies for the late response, we had a very heavy workload during July.
That looks very low… I wonder if this change in OpenWrt has something to do with it:
In summary, OpenWrt targets other than x86_64 have a reduced memory limit for fq_codel (32MiB->4MiB).
I did bring this to the attention of Dave Taht (RIP) once but I didn’t get any comments from him over it. There was a patch in our OpenWrt to treat arm64 the same as x86_64 but that fell out from the patchset for the newer versions.
I’m away on vacation for the next week but I’ll take a look later this month.
Interesting! ‘legacy’ mode can work better with passive DACs as it just depends on the link being electrically active rather than the complicated plumbing that Linux adds. With some link partners we have found optical cables to be more reliable for that reason. The TP-Link switch doesn’t look too expensive so we might buy one to replicate.
There are some pieces of the puzzle that have finally landed in upstream Linux that will make this possible. My priority in the next months is to go on a renewed “upstream” push to get this and other outstanding issues fixed.
I did make an attempt to upstream it in the past and it turned out there needed to be much more supporting work to be done first. The relevant subsystem maintainers also now (quite rightly) enforce much higher quality standards than in years past which made it harder for someone like myself to get all the work done.
No worries about the delay, so far this device is just something I’m experimenting with.
What’s the best way to update the recovery firmware?
I might try MuVirt again, to see if it does SQM any better than upstream OpenWRT. If MuVirt has an update, is there support for upgrading while keeping the same list of installed packages?
Speaking of the DAC, the last use case I tried was wan@eth9 → SX3008F switch, lan@eth8 → ConnectX-3 NIC (tried both Windows and Linux). The traffic on eth9 actually worked fine, only eth8 had issues; I didn’t try swapping them to see if it was a port-specific issue. Inbound on eth8, I saw some ipv6 multicast group-membership messages, but nothing else made it through, not even the DHCP requests from the NIC. Once I flipped sfpmode to legacy, all traffic started working. The DACs are 10Gtek SFP-H10GB-CU2M and SFP-H10GB-CU3M.
In terms of fan control, it would be nice to put it in percentage-based mode instead of RPM-based mode. With RPM-based mode, adding resistors doesn’t reduce the idle noise at all, it only reduces the maximum RPM. I had to add enough resistors that the fan can never go faster, but that means it could overheat under heavy load. With percentage-based mode, I could use lower-value resistors to reduce the idle noise while still allowing the speed to increase above that idle RPM.
I’m considering ditching the stock case that seems to resonate like crazy in favor of some sort of ITX case.
EDIT: Yes, muvirt gives much better SQM throughput in both directions.
So, given the huge difference in SQM throughput, how do we get OpenWRT upstream to have performance as good as the Traverse images?
I tried adding memlimit 32mb to the SQM options on vanilla OpenWRT, but the throughput stays low: around 200 megabits with packet steering disabled, around 600 with it enabled, and around 300 with enabled (all CPUs).
It’s on my list to look at soon (in the next few weeks), I’d like to run the bufferbloat test suite (flent) between the stock OpenWrt and our change (the memory patch) to confirm this.
I think the patch will need to be reworked to allow the buffer size to be selectable at kernel compile time (via a KConfig setting) so it can be implemented per-target/arch in OpenWrt.
It’s been a while, are there any new updates about the SQM performance difference?
I’ve found another performance issue which needs to be solved first. In general, recent OpenWrt releases have poor throughput (WAN->LAN) on the Ten64, much lower than we have previously seen. It has gone undetected as I did not have access to a fast (>1G) test site for a while.
The SQM setup in the kernel (4 vs 64MB buffer) doesn’t appear to be related to this, but the performance regression needs to be fixed first before we can do something about the SQM setup.
I will need to go through each major release (21.02/23.05/24.10 etc.) and see if the regression can be identified. (I think the transition to nftables/fw4 is the most likely regression point)
I have been busy on some customer projects for the last few months so I have not had as much time as I hoped to work on this, but I do have some time in the next few weeks to focus on it.
I’ve done some high speed testing today across various OpenWrt versions. Here is the current state of play:
General network performance
  • In OpenWrt mainline (and probably the new 25.xx) branch, 10G SFP’s are broken due a missing kernel backport, I have submitted a pull request to resolve this
  • In OpenWrt 24.10 and later, “packet steering” must be turned off
    Look under Interfaces->Global Network options in LuCI, or set network.globals.packet_steering=0 directly in UCI (credit goes to this comment on reddit)
    I am going to add a UCI default to our OpenWrt so it is disabled by default on the Ten64.
    (The DPAA2 hardware already balances flows between all available CPU cores so enabling this feature in OpenWrt will undo the setup already there)
  • Turning on “software flow offloading” (in LuCI->Routing) will significantly improve single-flow WAN->LAN performance (going from 1.1Gbit/s per flow to 2.5Gbit/s)
  • In general (without SQM), 23.05.x has the best throughput WAN->LAN when no optimizations (like software flow offloading) are enabled (this is out of 22.03,23.05 and 24.10)
SQM
  • I can see that the OpenWrt.org 24.10.x builds are significantly slower with SQM ingress shaping than anything we (Traverse) have built.
  • OpenWrt 23.05.5 seems to have higher peak rates in egress than any more recent version, if ingress/DL is turned on, the performance is closer to our >24.10.x results
  • The patch we previously carried (4MB vs 32MB memory limit in fq_codel) doesn’t seem to make a difference in simple iperf testing (it might be different with the flent test suite), but I have not ruled this out yet (also, the default WAN-side discipline is now cake, which doesn’t apply a memory limit)
  • The other possibility is that we have always built our images with Cortex-A53 as the compiler optimization target (-mtune=cortex-a53 -march=armv8-a+crypto+crc) while OpenWrt.org builds don’t target any specific CPU.
The sqm-scripts package has not changed since 23.05, so my guess is that a wider OpenWrt change after 23.05 is the cause of the performance issues. As some other targets gained full hardware offload support in 24.10 this might not have been noticed.
Thanks for doing such detailed testing. I tried downgrading to the OpenWrt upstream 23.05.6, and I still only get about 600-800 megabits ingress with SQM. I get about the same with the Traverse 24.10.2 image. I have flow offloading disabled because of the warning about not interacting well with SQM.
With upstream 24.10.5, I have to enable packet steering, because without it, I get about 260 megabits SQM throughput, and with it, I get about 800 megabits. Depending on build version (upstream or Traverse), it’s weird: on some images, ksoftirqd maxes out 100% of one core, and on others it’s around 85% maximum on a couple of cores. With the recent Traverse build, the CPU usage is even lower than that on various cores, so then what’s bottlenecking it?
Is it possible for the choice of interfaces to affect the performance? I’ve been using eth8 as LAN and eth9 as WAN. Come to think of it, would switching to a DPL that only exposes half of the 1-gigabit ports make any difference?
Since my cable modem has a 2.5GbE port but my internet plan itself is only 1 gigabit, I wonder if I’d be better off just linking to the cable modem at 1 gigabit and using only outbound SQM? I might have to try that sometime, when I have time for some downtime to swap stuff around.
I have been able to reproduce this interesting behaviour!
I think I understand what is going on:
  • The OpenWrt packet steering works by assigning processor affinity to each receive queue ( /sys/class/net/ethX/queues/ ).
    If the packet is initially received by the kernel on a different CPU core, it has to wait for that other CPU to become available (via Inter-Processor Interrupt), which causes performance (without SQM) to drop significantly.
    • Our hardware (DPAA2) already steers packets at the interrupt level (see grep dpio /proc/interrupts). When OpenWrt packet steering is turned off, packets can be processed by the same CPU core they are received on.
  • Various bits of SQM (qdisc) are single-threaded, so it’s advantageous for all traffic treated by SQM to be processed on a single core.
    When all the traffic is forced onto a single core (bad) the qdisc performance improves (good)!
On the ingress side there are are a couple of factors which stack up to make inbound performance worse than outbound:
  • Inbound performance in Linux generally worse due to the queueing / softirq system (things like XDP which avoid it perform much better)
  • Because Linux cannot shape inbound traffic, SQM relies on an IFB device to make inbound traffic look like outbound (see the sqm-scripts readme for a nice diagram). I haven’t profiled it, but I think this inbound->outbound->inbound loop is causing a severe performance penality.
I think it’s possible to improve the performance using a couple of hardware features:
  1. Steer all packets from the WAN side onto a specific CPU core (this can be configured using ethtool) to minimise the qdisc lock bottleneck
  2. Instead of the IFB, use a DPNI-DPNI link (it’s like a “hardware veth” device) to loop packets from the “inbound egress” back into the normal networking system (so the nftables/iptables etc. can be processed by any other CPU core)
  3. There are some hardware QoS/shaping features available (CEETM) that might be useful as a fallback, if the software mechanisms are too slow for the line rate
Part 2 requires a bit of work to implement, as the inbound side of SQM would need to be run inside a seperate network namespace. I’ve done something similar in the past to turn “single-threaded” network devices (like cellular modems) into multicore-ones with very promising results.
This does sound fun though, so I’ll set aside some time to do a PoC!
edit: I’ve discovered there is recent work on a multi-thread capable CAKE. Looks promising!
This is what I’ve been doing since I’ve had high speed connections (1G and now 2G).
I leave ingress SQM off but enable SQM on the outboud/egress path. The outbound is where the biggest “wins” are to be had, mostly by avoiding queueing or policing on the modem side.
The downside (AFAIK) is that the router won’t be able to use mechanisms like ECN when the downlink is under pressure, so some low latency applications will see a slight increase in latency.
To simulate having the Ten64 as primary router without mucking up the network, I tried disabling SQM on the upstream router and running outbound-only SQM on the Ten64 with a 1-gigabit link to the upstream router. The result on the bufferbloat test wasn’t great; I can’t remember exactly, but maybe a B. It’s possible other machines on the upstream LAN were sending some traffic at the time, though.
I’ll be curious to see what sort of prototypes you can come up with. For now, I’m still sticking with the x86 machine.
Separately, it would be good to try to get more of the upstream OpenWRT packages into the Traverse builds. At the very least, the Traverse builds could include commented-out opkg source declarations to make it easy to figure out which upstream repo branch to use for a given Traverse build.
mq-cake has landed in OpenWrt just recently and the results are promising.
It’s lifted the downlink performance ceiling from 1G/s to 2Gb/s (up to 3Gb/s might be possible with tuning of the flow->CPU distribution)
The caveat is that single-thread DL performance is the same (1 thread = ~880mbps).
These tests are done in a simulated setup (only to see where the bottlenecks are), but I will try testing it with a live connection and test tools sometime soon.
Looks like there’s a known issue of Cake MQ being slower than expected. I’ll keep an eye out for when the fix gets rolled out.
