I’ve been testing a SIM8200EA modem in this box now.
I can get it to connect to my provider both under OpenWRT, and under Fedora.
However I am not getting great speeds…
[root@fonzie ~]# speedtest-cli
Retrieving speedtest.net configuration...
Testing from Swisscom (178.197.236.173)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by TelemaxX Telekommunikation GmbH (Karlsruhe) [236.72 km]: 45.944 ms
Testing download speed................................................................................
Download: 57.28 Mbit/s
Testing upload speed......................................................................................................
Upload: 48.92 Mbit/s
mmcli -m 0 shows me that 5g is enabled and preferred. However, the 5G bands are not shown…
[root@fonzie ~]# mmcli -m 0
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: 2e07f1d9e9addb271e0d18946a5a5fc4b8325bbd
Hardware | manufacturer: QUALCOMM INCORPORATED
| model: 0
| firmware revision: MPSS.HI.2.0.c3-00180.2-SDX55_CPEALL_PACK-1 1 [Oct 02 2020 10:00:00]
| carrier config: Swiss-Comm
| carrier config revision: 0A010411
| h/w revision: 20000
| supported: gsm-umts, lte, 5gnr
| current: gsm-umts, lte, 5gnr
| equipment id: 864284040121233
System | device: /sys/devices/platform/soc/3110000.usb/xhci-hcd.2.auto/usb4/4-1/4-1.2
| drivers: option, qmi_wwan
| plugin: simtech
| primary port: cdc-wdm0
| ports: cdc-wdm0 (qmi), ttyUSB0 (qcdm), ttyUSB1 (gps),
| ttyUSB2 (at), ttyUSB3 (at), ttyUSB4 (audio), wwan0 (net)
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
| state: connected
| power state: on
| access tech: lte
| signal quality: 100% (cached)
Modes | supported: allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 3g, 4g; preferred: 4g
| allowed: 3g, 4g; preferred: 3g
| allowed: 5g; preferred: none
| allowed: 3g, 5g; preferred: 5g
| allowed: 3g, 5g; preferred: 3g
| allowed: 4g, 5g; preferred: 5g
| allowed: 4g, 5g; preferred: 4g
| allowed: 3g, 4g, 5g; preferred: 5g
| allowed: 3g, 4g, 5g; preferred: 4g
| allowed: 3g, 4g, 5g; preferred: 3g
| current: allowed: 4g, 5g; preferred: 5g
Bands | supported: utran-1, utran-3, utran-4, utran-6, utran-5, utran-8,
| utran-2, eutran-1, eutran-2, eutran-3, eutran-4, eutran-5, eutran-7,
| eutran-8, eutran-12, eutran-13, eutran-14, eutran-17, eutran-18,
| eutran-19, eutran-20, eutran-25, eutran-26, eutran-28, eutran-29,
| eutran-30, eutran-32, eutran-34, eutran-38, eutran-39, eutran-40,
| eutran-41, eutran-42, eutran-43, eutran-48, eutran-66, eutran-71
| current: utran-1, utran-3, utran-4, utran-6, utran-5, utran-8,
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 864284040121233
| enabled locks: fixed-dialing
| operator id: 22801
| operator name: Swisscom
| registration: home
3GPP EPS | ue mode of operation: csps-1
| initial bearer path: /org/freedesktop/ModemManager1/Bearer/0
| initial bearer apn: GPRS.SWISSCOM.CH
| initial bearer ip type: ipv4
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/1
| sim slot paths: slot 1: /org/freedesktop/ModemManager1/SIM/0
| slot 2: none (active)
Bearer | paths: /org/freedesktop/ModemManager1/Bearer/1
Only the LTE bands are shown, not the newer 5G NR. But that could be a ModemManager issue?
Note that where I live 5G uses the n1 band.
Is there something I overlooked? Something I need to set?
