I tried multiple aspects now, but I am stuck:
In /etc/config/virt I added:
list disks '/vm/MYIMG.qcow2 /dev/sda'
did not work, then I tried:
list disks '/vm/MYIMG.qcow2'
list disks '/dev/sda'
Did not work either.
Then I double checked muvirt/files/muvirt.init · master · traversetech / muvirt-feed · GitLab and noticed that there is a option for pcidevice to pass. My idea: pass the entire SATA controller:
root@muvirt:/# lspci
0000:00:00.0 PCI bridge: Freescale Semiconductor Inc Device 80c0 (rev 10)
0001:00:00.0 PCI bridge: Freescale Semiconductor Inc Device 80c0 (rev 10)
0001:01:00.0 PCI bridge: Pericom Semiconductor Device b304 (rev 01)
0001:02:01.0 PCI bridge: Pericom Semiconductor Device b304 (rev 01)
0001:02:02.0 PCI bridge: Pericom Semiconductor Device b304 (rev 01)
0001:04:00.0 Unclassified device [0002]: MEDIATEK Corp. MT7915E 802.11ax PCI Express Wireless Network Adapter
0002:00:00.0 PCI bridge: Freescale Semiconductor Inc Device 80c0 (rev 10)
0002:01:00.0 SATA controller: JMicron Technology Corp. JMB58x AHCI SATA controller (rev ff)
Hence, added to /etc/config/virt:
option pcidevice '0002:01:00.0'
When starting the VM again, it looks as if the kernel crashes:
root@muvirt:/# /etc/init.d/muvirt start vm
Starting VM vm
Disk 0: /vm/vm.qcow2
Network 0: lan
MAC: 52:54:00:93:25:f9
root@muvirt:/# [ 1416.789560] br-lan: port 2(tap0) entered blocking state
[ 1416.794798] br-lan: port 2(tap0) entered disabled state
[ 1416.800238] device tap0 entered promiscuous mode
[ 1416.805263] br-lan: port 2(tap0) entered blocking state
[ 1416.810504] br-lan: port 2(tap0) entered listening state
[ 1418.684658] qemu-system-aar invoked oom-killer: gfp_mask=0x100dca(GFP_HIGHUSER_MOVABLE|__GFP_ZERO), order=0, oom_score_adj=0
[ 1418.695887] CPU: 1 PID: 8706 Comm: qemu-system-aar Not tainted 5.10.46 #0
[ 1418.702669] Hardware name: traverse ten64/ten64, BIOS 2020.07-rc1-gb47b96d4 07/07/2021
[ 1418.710581] Call trace:
[ 1418.713024] dump_backtrace+0x0/0x1b0
[ 1418.716681] show_stack+0x18/0x30
[ 1418.719990] dump_stack+0xdc/0x11c
[ 1418.723383] dump_header+0x44/0x184
[ 1418.726867] oom_kill_process+0x1d0/0x1d8
[ 1418.730869] out_of_memory+0x1bc/0x560
[ 1418.734611] __alloc_pages_slowpath.constprop.126+0x71c/0xa10
[ 1418.740350] __alloc_pages_nodemask+0x25c/0x2a0
[ 1418.744876] alloc_pages_vma+0x8c/0x220
[ 1418.748706] handle_mm_fault+0x7b0/0x1048
[ 1418.752709] __get_user_pages+0x1e4/0x388
[ 1418.756711] __gup_longterm_locked+0x8c/0x4a8
[ 1418.761061] __get_user_pages_remote+0x48/0x2b0
[ 1418.765584] pin_user_pages_remote+0x18/0x30
[ 1418.769851] 0xffff800008cb9f50
[ 1418.772984] 0xffff800008cba238
[ 1418.776118] 0xffff800008cbd2d0
[ 1418.779254] vfio_group_set_kvm+0xcc/0x590 [vfio]
[ 1418.783954] __arm64_sys_ioctl+0x1cc/0x1120
[ 1418.788131] do_el0_svc+0x80/0xe0
[ 1418.791440] el0_svc+0x18/0x28
[ 1418.794486] el0_sync_handler+0x90/0xc8
[ 1418.798316] el0_sync+0x164/0x180
[ 1418.801759] Mem-Info:
[ 1418.804031] active_anon:3097 inactive_anon:1166263 isolated_anon:0
[ 1418.804031] active_file:95 inactive_file:207 isolated_file:0
[ 1418.804031] unevictable:0 dirty:0 writeback:0
[ 1418.804031] slab_reclaimable:1524 slab_unreclaimable:9242
[ 1418.804031] mapped:491 shmem:970 pagetables:2526 bounce:0
[ 1418.804031] free:34204 free_pcp:577 free_cma:1000
[ 1418.821353] br-lan: port 2(tap0) entered learning state
[ 1418.836103] Node 0 active_anon:12388kB inactive_anon:4665052kB active_file:380kB inactive_file:1120kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:2256kB dirty:0kB writeback:0kB shmem:3880kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 4562944kB writeback_tmp:0kB kernel_stack:3056kB all_unreclaimable? yes
[ 1418.869820] Node 0 DMA free:120028kB min:996kB low:2956kB high:4916kB reserved_highatomic:0KB active_anon:0kB inactive_anon:1825512kB active_file:112kB inactive_file:2304kB unevictable:0kB writepending:0kB present:2029568kB managed:1963964kB mlocked:0kB pagetables:1952kB bounce:0kB free_pcp:796kB local_pcp:244kB free_cma:4000kB
[ 1418.898853] lowmem_reserve[]: 0 0 29570 29570
[ 1418.903379] Node 0 Normal free:15276kB min:15384kB low:45664kB high:75944kB reserved_highatomic:0KB active_anon:12300kB inactive_anon:2839156kB active_file:924kB inactive_file:260kB unevictable:0kB writepending:0kB present:30932992kB managed:30281508kB mlocked:0kB pagetables:8152kB bounce:0kB free_pcp:1612kB local_pcp:164kB free_cma:0kB
[ 1418.933192] lowmem_reserve[]: 0 0 0 0
[ 1418.937017] Node 0 DMA: 0*4kB 3*8kB (UC) 2*16kB (UC) 4*32kB (C) 6*64kB (UMC) 3*128kB (U) 2*256kB (UM) 4*512kB (UMC) 2*1024kB (MC) 2*2048kB (MC) 27*4096kB (M) = 120248kB
[ 1418.952095] Node 0 Normal: 1027*4kB (UME) 400*8kB (UME) 133*16kB (UE) 35*32kB (UE) 19*64kB (UE) 5*128kB (ME) 6*256kB (UME) 3*512kB (UM) 1*1024kB (M) 0*2048kB 0*4096kB = 16508kB
[ 1418.968030] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB
[ 1418.976807] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=32768kB
[ 1418.985410] Node 0 hugepages_total=13340 hugepages_free=13340 hugepages_surp=0 hugepages_size=2048kB
[ 1418.994621] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=64kB
[ 1419.002964] 1693 total pagecache pages
[ 1419.006790] 0 pages in swap cache
[ 1419.010182] Swap cache stats: add 0, delete 0, find 0/0
[ 1419.015484] Free swap = 0kB
[ 1419.018441] Total swap = 0kB
[ 1419.021397] 8240640 pages RAM
[ 1419.024435] 0 pages HighMem/MovableOnly
[ 1419.028269] 179272 pages reserved
[ 1419.031581] 4096 pages cma reserved
[ 1419.035147] Tasks state (memory values in pages):
[ 1419.039929] [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name
[ 1419.048647] [ 1821] 81 1821 307 12 49152 0 0 ubusd
[ 1419.056987] [ 1832] 0 1832 327 15 40960 0 0 ash
[ 1419.064998] [ 1914] 0 1914 242 11 32768 0 0 urngd
[ 1419.073258] [ 2837] 514 2837 301 96 36864 0 0 logd
[ 1419.081434] [ 2933] 0 2933 538 49 45056 0 0 rpcd
[ 1419.089608] [ 3044] 0 3044 365 10 36864 0 0 mdadm
[ 1419.097870] [ 3142] 0 3142 261 10 36864 0 0 dropbear
[ 1419.106311] [ 3189] 0 3189 608 14 40960 0 0 hostapd
[ 1419.114748] [ 3192] 101 3192 1378 113 53248 0 0 hostapd
[ 1419.123183] [ 3250] 0 3250 456 54 40960 0 0 netifd
[ 1419.131531] [ 3335] 0 3335 326 13 36864 0 0 crond
[ 1419.139792] [ 4116] 0 4116 392 23 40960 0 0 uhttpd
[ 1419.148141] [ 4176] 0 4176 435 32 40960 0 0 dbus-daemon
[ 1419.156922] [ 4335] 0 4335 361 24 40960 0 0 blockd
[ 1419.165270] [ 4528] 0 4528 1731 209 45056 0 0 nginx
[ 1419.173531] [ 4558] 0 4558 1786 259 45056 0 0 nginx
[ 1419.181791] [ 4559] 0 4559 1786 259 45056 0 0 nginx
[ 1419.190052] [ 4560] 0 4560 1786 259 45056 0 0 nginx
[ 1419.198314] [ 4561] 0 4561 1786 259 45056 0 0 nginx
[ 1419.206575] [ 4562] 0 4562 1786 259 45056 0 0 nginx
[ 1419.214837] [ 4563] 0 4563 1786 259 45056 0 0 nginx
[ 1419.223099] [ 4565] 0 4565 1786 258 45056 0 0 nginx
[ 1419.231279] [ 4566] 0 4566 1786 259 45056 0 0 nginx
[ 1419.239540] [ 5117] 0 5117 563 46 40960 0 0 starter
[ 1419.247974] [ 5154] 0 5154 1953 149 49152 0 0 charon
[ 1419.256323] [ 5576] 0 5576 608 21 36864 0 0 muvirt-console
[ 1419.265287] [ 5579] 0 5579 325 138 32768 0 0 sh
[ 1419.273290] [ 5581] 0 5581 325 138 32768 0 0 sleep
[ 1419.281552] [ 5643] 0 5643 608 25 40960 0 0 ntpd
[ 1419.289727] [ 5647] 123 5647 325 14 36864 0 0 ntpd
[ 1419.297902] [ 5792] 0 5792 1408 96 49152 0 0 ttyd
[ 1419.306081] [ 6229] 0 6229 4212 399 69632 0 0 ModemManager
[ 1419.314951] [ 6692] 0 6692 251 16 36864 0 0 odhcp6c
[ 1419.323390] [ 8706] 0 8706 7909338 1166141 9445376 0 0 qemu-system-aar
[ 1419.332437] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=qemu-system-aar,pid=8706,uid=0
[ 1419.345861] Out of memory: Killed process 8706 (qemu-system-aar) total-vm:31637352kB, anon-rss:4664564kB, file-rss:0kB, shmem-rss:0kB, UID:0 pgtables:9224kB oom_score_adj:0
[ 1419.373706] oom_reaper: reaped process 8706 (qemu-system-aar), now anon-rss:0kB, file-rss:32kB, shmem-rss:0kB
[ 1419.772608] br-lan: port 2(tap0) entered disabled state
[ 1419.778167] device tap0 left promiscuous mode
[ 1419.782531] br-lan: port 2(tap0) entered disabled state
So, as there is a segfault, I went back into the muvirt/files/muvirt.init · master · traversetech / muvirt-feed · GitLab, and there in line 256 I see that the script runs a modprobe vfio-pci.
With the latest uVirt supplied, I ran:
root@muvirt:/# cat /etc/openwrt_release
DISTRIB_ID='muvirt'
DISTRIB_RELEASE='21.02-SNAPSHOT'
DISTRIB_REVISION='r0+16214-8e81d977ac'
DISTRIB_TARGET='arm64/efi'
DISTRIB_ARCH='aarch64_generic'
DISTRIB_DESCRIPTION='muvirt 21.02-SNAPSHOT r0+16214-8e81d977ac'
DISTRIB_TAINTS='no-all busybox'
root@muvirt:/# modprobe vfio-pci
root@muvirt:/# lsmod | grep vfio-pci
root@muvirt:/#
While I thought the driver is missing, I noticed that just the script is wrong, as vfio uses a underscore:
vfio 28672 3 vfio_pci,vfio_iommu_type1,vfio_fsl_mc
vfio_fsl_mc 20480 0
vfio_iommu_type1 36864 0
vfio_pci 57344 0
vfio_virqfd 16384 1 vfio_pci
Now, I am puzzled why passing the SATA controller does not function.
At the same time: how can I just directly pass through a device?
